'87 325i, many faults need answers
jimf
Post Sat Sep 17, 2011 10:22 pm
Hi, I've just arrived home with my new winter project car. It's a 1987 325i cabriolet. It needs a load of stuff done and this is my first E30 in a while so could do with some pointers please. I'm hoping these are comon faults and someone will be able to suggest what the usual fixes are.
Firstly, if the temp needle fluctuates between half way and 3/4. Does that indicate thermostat issue?
2. One of the rear indicators wont work, the bulb is ok and it works with the hazzards. When the indicator in either direction is selected they flash at double speed as if the bulb is blown
3. The wipers stop in the up position when i turn them off and i have to hold the stalk down to get them to settle in the right place.
4. The indicators don't self cancel, maybe they dont on the early models, i don't know.
5. The fuel gauge needle is stuck but apparently the warning light functions as it should, is it likely to be the cluster or the the sender.
Well I think that is enough to be getting on with for now but I'm sure there will be many more to come.
Post Sat Sep 17, 2011 10:36 pm
1 ) Indicator stalk is probably fooked - replace it and it will probably cure your non working one and non-self-cancelling
2 ) Temp needle could be a cooling system issue or if the needle is flickering could be a loose nut on the back of the cluster - cooling system issues commonly stuck thermostat/airlock/fooked rad/inop viscous fan - all common, all fairly easily fixable.
3 ) Wiper motor needs a refurb - guide on the Wiki how to sort it
4 ) There is a way to "earth" the fuel gauge - meaning when you switch on the ignition it will go all the way to "full" - if it does this the gauge is OK its the sender that requires replacement - can't remember how to do it offhand but this is what you need to check - there is an inspection panel under the rear seat base which will allow you access.
jimf
Post Sat Sep 17, 2011 10:44 pm
Excellent reply mate, thank you
