Facelift Front Fogs Help
e-thirty
Hi zoners, ive just acquired a e30 facelift model, it has no front fogs but has air ducts, what would i need if i wanted to fit front fogs, all i have is the 2 fogs and a switch, as i tried fitting the fogs on the 318i but the battery drained out
MurphyE30
you have all you need
the looms are already there for you to plug the fogs in. you will need to add the correct relay aswell
Beside the air ducts, there should be fog light sized blanks where the fog lights fit.
You will need the foglights, the brackets they mount in, the plastic fixings for the body that the screws for the brackets fix in to, two 7.5A fuses, a black relay for position K8 in the fusebox, identical to the one in K4 next to it, a tell tale light for the instrument cluster, and a dual foglight switch to replace the existing rear foglight switch.
All wiring should already be in place.
