Gave my car a quick once over today ready for the MOT. Got a few issues.
Will it fail for the brake pad wear light? If so how can this be remedied easily? (The pads are fine)
The T junction gadget separating the water entering the washer jets is not working (didn't notice before as I've never tried to use the washers...) So I bodged it so that the water flows directly into the drivers side sprayer only. Is this adequate or will I need to replace the T junction thing?
The o/s sidelight is noticeably dimmer than the other (also still works fine). Is this okay?
Pre-MOT queries
cee
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Won't fail for pad wear light as long as the brakes work as they should.
AFAIK both jets need to work - those non-return T pieces are a pain in the arse - I've just replaced my E30 ones which was a bastid fiddly job. On my old E36 I removed them and put the hose straight onto the jets which didnt seem to have any ill effects.
You could always just get a small piece of plastic pipe from an auto accessory shop rather than the non-return valve - IIRC the valves themselves are about £7 each from BMW
Both sidelights should be equal brightness really - is the bulb damaged/dirty ? try cleaning the earth connections.
cee
I couldn't work out how to get the light assembly out
(uhoh blonde moment) and didn't have my Haynes with me. Will research it tonight and see what I can do tomorrow. Then again, it's always been like that since I bought it and it was MOT'd a few days before my purchase.
I really don't get the non return valve, water enters it, but shoots out of two random holes, rather than the correct holes which lead to the jets.....
- **BANNED**
I think that any standard non-return valve/T piece will do the job.
Sidelight bulb is right on top of the light unit,a bayonet type fitting....assuming the headlight is as bright as it's mate,perhaps the bulb is giving up slowly?
Youth is wasted on the young.
cee
The headlight is fine, but looks to be a different bulb as the light comes from the middle rather than the top. Heading back over to where the car's stored tomorrow so will see if I can get it apart.
