Intensive Wash Setup/Test
Post Sat Sep 10, 2011 6:06 pm
Trying to get my head round the intesive wash setup on my touring.
Have I got this right - 3 motors :
1 into main reservoir works when the stalk is pulled towards you to wash the screen
2 works in conjunction with 1 for intensive wash of screen from smaller reservior when stalk is pressed in
3 into back of main reservoir for headlamp washers
How does the headlamp wash/wipe system work ?
Headlights have to be on obviously but does it work every time you use the "normal" wash, or just when you use the intesive wash ? or some other way ?
I've identified which plug does which by a process of elimination - the screen and intensive wash pumps work as they should but with the lights on I couldnt seem to get the pump for the washers to work - is this a duff relay or what else should I check ? Is there a way to test the relay ?
**BANNED**
Post Sat Sep 10, 2011 6:47 pm
Knowledge here is sketchy,but I understand that the headlight wash/wipe fires up every 5th use of the screenwash....when the headlights are in use...
So you will get very wet testing....
Youth is wasted on the young.
threelander
Post Sat Sep 10, 2011 6:59 pm
more likely to be the non return valves on the pipes leading to the jets on the grills m8 follow the pipes from the pump on the back of the bottles and you will come across a valve to each side i think these would need changing
Post Sat Sep 10, 2011 7:36 pm
Before I can check the non return valves to the headlamp washer jets I need to get the pump working - no success so far.
threelander
Post Sat Sep 10, 2011 7:44 pm
so my guess you need new pump relay must be ok otherwise other stuff wunt work.do you have the ten pin relay in fuse box k6 relay i think.normal one is 8 pin you need 10 pin one
Post Sat Sep 10, 2011 7:48 pm
Thought it was the black relay on the bracket by the washer bottle that worked the HLWW system ?
Post Sat Sep 10, 2011 8:57 pm
The headlamp WIPERS work every fifth or sixth time the normal screenwashers are used when the sidelights are on. Working them five or six times in quick succession doesn't seem to work though, in my experience.
I actually started tracing out the internal circuitry of the control module on the washer bottle, about three months ago, to see exactly how it works, but got sidetracked.
One of the headlamp wiper motors has a three pin plug and the other four. When the wiper motor with four wires starts to move, it switches power to the headlamp washer motor, and sprays screenwash onto the headlamps for the first half of the wiper motor's sequence of wipes.
Jozi
Post Sun Sep 11, 2011 12:03 pm
Slightly off topic maybe, are these hard to retrofit and are all plugs present in the engine by but unused? I figure I have all this ahead of me as well.
**BANNED**
Post Sun Sep 11, 2011 12:47 pm
How practical would it be to simplify this system so that the headlight wipers worked when ever the windscreen wipers and headlights were used? :D
rover-2000
Post Sun Sep 11, 2011 1:03 pm
daimlerman wrote:How practical would it be to simplify this system so that the headlight wipers worked when ever the windscreen wipers and headlights were used? :D
Or just worked from a switch in the car ?
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
Post Sun Sep 11, 2011 2:32 pm
Working from a switch would be very easy. Just needs a short pulse from a push button to start the headlamp wipers, and from then on the wash/wipe sequence is automatic, controlled by the wiper motors themselves.
rover-2000
Post Sun Sep 11, 2011 4:07 pm
I think I might go down that route once I get ours working, using a small push button switch discreetly sited. Any ideas how/where I would need to wire it in ?
Thanks.
Kind regards
John
1989 320i Touring
threelander
Post Sun Sep 11, 2011 4:15 pm
if its gonna work it,s gonna work from the stalk yeh if it don,t work from there you can fit 20 buttons but it,s not gonna work
rover-2000
Post Sun Sep 11, 2011 4:45 pm
threelander wrote:if its gonna work it,s gonna work from the stalk yeh if it don,t work from there you can fit 20 buttons but it,s not gonna work
Eh ? :?
Kind regards
John
1989 320i Touring
Post Sun Sep 11, 2011 10:13 pm
What I was thinking really. The control module on the washer bottle is generally reliable, as long as it's not lying upside down on the chassis rail and full of water. It's the wiper motors themselves that give trouble on E30s, not the control system.
If you still want to go ahead with a push button, an intensive wash wiper stalk, or an OBC type indicator stalk could be used, as long as you don't ant intensive wash or have an OBC, of course.
Both these stalks switch to earth, so you'd need to add in a relay (30 and 86 to purple/black 12 volts feed, 87 to the wiper motors trigger pins, and 85 to the switch.)
rover-2000
Post Mon Sep 12, 2011 9:00 am
Thanks for that. It wasn't the point I was trying to convey though. My system doesnt work because the motors are seized-I know that and I know how to fix it. What I was trying to convey is that I think the mode of operation isn't very logical/ satisfactory-I would rather have manual control over them (Hence wanting to convert to a switch....)
Kind regards
John
1989 320i Touring
