BMW 316 1.8 Pierberg 2BE to Weber 32 34 DMTL
MARS7AN
Post Tue Sep 06, 2011 7:21 pm
Hello I've just bought a Weber 32 34 carb to replace the Pierberg 2BE as I was having problems with hesitation. Can anyone help me with fitting it.
The first thing that worry's me is that the Pierberg 2BE is automatic choke and the Weber 32 34 DMTL is manual so adjustments need to be made there.
The next thing is when I look at the Pierberg compared to the Weber I see plenty of tubes and connection that dont exist on the Weber. Can anyone explain what happens to the redundant Pierberg connection and tubes?
Thanks Mark
Post Tue Sep 06, 2011 11:46 pm
A looong time since I fitted one of these, and the memory isn't what it used to be!
You will need to obtain and fit a manual choke cable inside the car. These were readily available when I last needed one, but are much more of a rarity these days, although suppliers of parts for kit cars should be able to help if you can't find one elsewhere.
It will need a 13mm hole drilled in the dash somewhere within reach of the driver, and bear in mind that the cable will have to go the bulkhead behind the dash when choosing the position.
Most of the tubes, wires and sensors associated with the Pierburg are simply abandoned or removed and discarded. The only tube that is retained, as far as I can remember, is the vacuum advance tube to the distributor.
Any unused stub pipes or tubes that lead into the inlet tract must be blanked off.
MARS7AN
Post Wed Sep 07, 2011 5:46 pm
Okay thanks for the help. Can I ask how did it run afterwards. Did it feel much better?
DHFiS
Post Wed Sep 07, 2011 9:02 pm
I fitted a Weber on mine after the Pierburg wore out and dripped neat fuel into the inlet manifold.
The Weber was a great improvement.
Joe-318i
Post Wed Sep 07, 2011 9:17 pm
I have one fitted on mine, was done by the last owner i think
find it easy to drive with, i use the car every day, find it tobe responsive, sounds good when the second choke opens too and returns about 240-270 miles to a tank of fule, i just give the filter and inside of carb a clean now and then and oil it up
heres a pic, hope it helps, i can take a few more close ups if you want
'83 320i chromie
'86 316 tech 1/M20B25 conversion
'91 318is touring
'87 chromie M10 rightness
Joe-318i
Post Thu Sep 08, 2011 9:05 am
MARS7AN wrote:Okay thanks for the help. Can I ask how did it run afterwards. Did it feel much better?
The problem with the Pierburg on the one I changed was that the idle potentiometer was beyond help, so that the engine would not idle.
The Weber carb. is a far less sophisticated device than the Pierburg, with a manual choke and no idle stabilisation, etc., but on old carbs. less sophisticated (i.e. simple) is good.
The correct kit should come with an adaptor ring to enable you to use the OE air filter, instead of aftermarket rubbish.
MARS7AN
Post Thu Sep 08, 2011 11:31 am
Joe is you could that would be great as not sure which tubes and connections are no longer used. Could you tell me what connections you have on the new one and where they go?
Joe-318i
Post Fri Sep 09, 2011 5:34 pm
MARS7AN wrote:Joe is you could that would be great as not sure which tubes and connections are no longer used. Could you tell me what connections you have on the new one and where they go?
no problem
ill take a few more close up pics
and ill do my best with finding out what goes where :D
'83 320i chromie
'91 318is touring
Joe-318i
MARS7AN
Post Fri Sep 09, 2011 6:46 pm
Thanks. I think I may have cracked it though. I've just bolted it on and fitted the tubes which I guessed went where which is only 2 in total and connected up the accelerator cable. I temporary opened the choke by using a bit of cable to hold it there rather than start cutting the holes in dash before I know it makes an improvement. I took it up dual carriageway with no filter just to try it and wow what an improvement. Hesitation gone and it dont half shift. Will be even better once I've set it up properly with choke in place and idleing at 600-700rpm.
2 questions if you dont mind guys.
Before the car reved at 600-700rpm. What's the range now with it being manual choke. When i start it up what should it be revving at and what should it be when idleing?
Lastly would you put back the original filter or go for a K and N?
Post Fri Sep 09, 2011 7:30 pm
Hot idle speed for your car is 850 RPM +/- 50 RPM, according to Autodata.
Cold idle speed should be a little more.
OE filter assembly is superior to a K & N in every way!
DHFiS
Post Fri Sep 09, 2011 8:53 pm
I fitted the choke in the under dash panel which was a mistake as eventually you pull it off.
Choke cables are for sale on Ebay.
Joe-318i
Post Fri Sep 09, 2011 8:55 pm
Brianmoooore wrote:Hot idle speed for your car is 850 RPM +/- 50 RPM, according to Autodata.
whats the diffrence then?
the k&n was already fitted on mine and seems to be fine
'83 320i chromie
'91 318is touring
Joe-318i
Post Fri Sep 09, 2011 11:00 pm
OE filter (if clean) has a much greater filter area than the K&N, ducts cold air from outside, actually filters the air, and reduces intake noise.
Andyboy
Alpina Colada
Post Sun Sep 11, 2011 7:41 pm
The K&N isn't bad, and a properly oiled one filters well. But they look a bit daft (imo) and unless you duct cool air in, you'll lose performance due to the different density of warm air.
I don't reckon much to the Weber replacements. They're made by Webcon and are a bit crap in terms of quality, throttle response and graduation between the first and second chokes. I fitted a Weber 32/36 from a 2 litre Ford Pinto once, using the heater hoses to connect up the automatic choke (which worked well on these) and a Webcon adaptor plate. I used standard 2.0 jets and once the CO was set up, it went like a rocket - I'd say it gained 10-15 bhp over standard. I used the Sierra 2.0 air filter housing with the FORD lettering Dremelled off. :D
