Right, I have just recieved my AB/100/17 6 point bolt in OMP cage and im not sure if i have recieved all of the fixings, Bought it from balence motorsport but the man who runs it is clueless. Just wondered if anybody had pics of theres if anybody uses tem etc.
Any info on this cage would be brilliant
cheers
stevie
Rollcage help
rix313
What fixings do you think are missing? If it's nuts and bolts just measure up what you need and get some ordered from your local fixings establishment.
Mikey_Boy
+1 - make sure they are strong enough for the job though... 10.9 or 12.9 normally do the job.
Good luck!
Mike
Good luck!
Mike
rix313
Ah yes. If space allows use capheads and not dome heads.
stevie-p
Got it all sorted now fella's thanks, I was missing 2 gudgeon pins for the door bars
