My air con is dealer fit (no I'm not planning to rip it out, it works OK for now), and it doesn't give the 12v signal on the ECU pin for increased idle. Very ocasionally the car stalls.
So if I wish to connect the purple / black wire to a 12v feed when the air con is on, do I need to find a 12v live when the compressor is running only or is it sufficient to wire it the switch on the dash so that it gets the signal constantly regardless of the compressor status ?
A second question is, where is the other end of the purple / black wire ? One end is at the ecu plug, but then it disappears into the loom....
Air con purple / black idle signal question
clipper
Other end of the purple/black is at one of the ECU pins.
Not sure exactly how the dealer fit air con is wired, but presumably there is a switch to turn it on, that has 12 volts ignition switched going into it. You need to connect to the 'out' side of this switch, so there is 12 volts on the purple/black all the time the aircon is switched on.
clipper
OK thanks, direct from "on switch" to purple / black it is then !
FYI Brian, the "on switch" is a "BMW look a like" double width button, a bit like a hazard or rear window heater switch which fits in to the HVAC / Radio panel where the standard BMW a/c - recycle buttons go, and lights up blue when on.
