diff bush
chinna
Post Fri Sep 02, 2011 10:16 am
i have a bad vibration through the whole car between 60 and 70 mph.1990 325 auto cabby 115000 miles. seems to have occured over night? only really get up to 60 on the dual carriageway but driving to brum airport the other day. all prop and gearbox bushes were renewed less than 12 months ago (genuine parts), diff has clean oil in it. all wheel bolts done up and no loss of weights? neither of the rear wheel have weights on the outside and there are no tell tale marks to say there were any? used to fit wheels and tyres for jag/landrover. rear beam bushes fitted over 2 years ago along with rear bearings so running out of options other than the diff itself or diff bush. looking at the diff bush it looks soild on both sides but the bottom isn't attatched to the metal ring the bolt goes through to hold it up. can't see the to of the bush as it's mounted to the car? through the cold ie minus degrees, the diff used to let out a high pitched whine gettin louder up to 30mph then stop. this was only when left over night. after all that blabber does anyone have any ideas as to my vibration, diff, diff bush, go and get the wheels balanced?
