z3 shift kit / gear linkage renewal
randomspeedfreak
Post Thu Sep 01, 2011 2:24 pm
ive just read through this:
http://www.e30zone.net/e30zonewiki/inde ... conversion
he mentions changing the 'selector rod bush ' is this the bit on the gearbox end of things? i need to change this i think on mine there is a fair bit of play there
does anyone know what's involved with this job?
cheers,
Matt
Post Thu Sep 01, 2011 5:23 pm
Its a fiddly dirty job. And if you've only got axle stands it is even more awkward.
Lots of prep before you start :
unclip the fan shroud in the engine bay to stop the fan fouling it when the gearbox is lowered
Remove exhaust, prop and heatshield
remove gearbox mounting crossmember which will drop the back of the gearbox down - only then can you get at the linkage.
Its a good job these things last a long time because I wouldnt want to do it again in a hurry.
All the bits to do the job should cost you under £100 - replace ALL the bushes/washers etc - skimping is pointless - do it properly or don't bother.
You may also find you need a new propshaft guibo and gearbox mounts - thats another £100 if you use genuine parts.
There are some pics on my touring resto thread of the bits required to do this job.
