Clutch slave cylinder replacement.
Von_Thrash
Post Thu Sep 01, 2011 12:15 pm
. . . is it easy to do? Pretty sure the reason i have no clutch is a leaking slave cylinder, (pool of fluid under car, biting point moved when you pressed the clutch down for anything more than 5 seconds before it went completely). I have one removed from a pre-facelift 320i, only a few months old - will it fit my 1989 325i?
Thanks in advance.
**BANNED**
Post Thu Sep 01, 2011 12:31 pm
Two 13mm nuts,I think.
Top one can be playfull to get at,try to slack off the hose before you remove the cylinder.Flexi is horribly expensive via BMW,but some-one put up a link to an Ebay s/s one the other day,a far more reasonable £22ish.
Most suggest that the master cylinder is swapped at the same time.
Youth is wasted on the young.
Jozi
Post Thu Sep 01, 2011 2:05 pm
S/s hose is something I must get, any idea who posted it up Malc? I'll get searching for it.
---EDIT---
Unbelievable I found it using the search :P
http://www.ebay.co.uk/itm/BMW-3-Series- ... 45fcc6c924
Von_Thrash
Post Thu Sep 01, 2011 7:14 pm
Happy :D
Got home from work at 6pm, just finished a short test drive after fixy fixy. Thanks again!
