Hi chaps
the green illuminated switch has stopped working on my touring's dash, its the one on the right that activates the rear window wash wipe, any suggestions on fixing, thanks alot, Mike
Rear wiper switch /green light
Probable that the bulb has simply blown. They're not intended to be replaced, but it's fairly easy to do so. Never actually changed one in this particular switch, but I've changed several in window switches, which are of very similar construction.
Switch is easy to strip down, and suitable wire ended miniature bulbs are available from CPC Farnel.
mikehoddy
Thanks alot - will check it out - how do i take out the switch please?
Switch just pulls out. If there's a blank next to it, it's easiest to remove this and stick your finger in the resulting hole to hook it out.
mikehoddy
Hi
i took out the switches and replaced both bulbs (12v 1.2w bulbs), like for like - just the same as before- the intermittent bulb on the left works but the wash/wipe on the right bulb does not light up - strange - any further suggestions?
Do you mean the bulb doesn't light when the button is pushed, or when the sidelights/panel lights are on?
mikehoddy
yes, the bulb does'nt light up when pushed, the sidelight/panel is all good. They light up even when sidelights are off
mikehoddy
Sorry, i know what you mean now, yes, both the switches light up (glow slightly) when i turn on side lights, also hazard button etc. - but when was/wipe switch is depressed the bright green glow does'nt happen but its fine on the wipe button on the left, hope this helps, thanks, Mike
They're doing what they're supposed to do! The intermittent wipe is a latching switch, so needs a tell tale. The washer is just a push button, can't be latched on, so doesn't need a tell tale.
You can have the sidelights on without the panel lights and number plate lights (column parking light switch), but you shouldn't be able to have things the other way around.
mikehoddy
Think i get you...so you are saying that the intermittent needs a tell tale so you know its on - the wash/wipe doesnt because it doesnt stay on (so not latched on) like the just wipe switch. So you are saying the wash/wipe only glows when side/full beam lights are on? and doesnt light up brightly like the intermittent switch?
mikehoddy
Hi again, just another thing - indicator does not self cancel - what could the issue be? Please could you tell me how to check ie what to take off etc, regards, Mike
Take the steering wheel off and have a look. The mechanism should be visible with it off.
There should be a little plastic tab sticking out from the indicator switch, and it should be obvious what it engages with.
