Recently noticed the following issue, after say 10mins of driving whenever I press the brake pedal to slow down, the oil light flicks on & off.
Oil level seems fine, anything I should be checking such as earth/ground connections?
I will be changing the rocker cover gasket as there is a slight leak near the front.
Oil light...
Topblag
Have you checked the levels using the dipstick ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
oomz1975
