And now the car's run out of battery.
One more question, if the battery has been drained too much, will the car be able to jump start? Because right now I can't jump start the car. Dash lights are very dim I can barely see them (but still on!)
if it were a diesel then the engine is pretty much dead because the con-rods would have bent, because it is a petrol engine then it is very unlikely to have engine damage, once the spark-plugs are dry the engine should start and the water will burn away, where with a diesel once it has turned/or even started the con-rods will be bent, done this to my astra diesel and had a big lecture from aa manpac1982 wrote:If your car has sucked water in to the engine via the air intake it could be a ****** engine not just ****** electrics which would explain why it wont start even via a bump
jbh recently done an engine change on a 325i touring that had been driven into water and hydrolocked which had bent con rods.bmwbmwbmw wrote:if it were a diesel then the engine is pretty much dead because the con-rods would have bent, because it is a petrol engine then it is very unlikely to have engine damage, once the spark-plugs are dry the engine should start and the water will burn away, where with a diesel once it has turned/or even started the con-rods will be bent, done this to my astra diesel and had a big lecture from aa man
