Gearbox Research
Adams-Sideways
Post Fri Aug 26, 2011 2:57 pm
hi there
My gearbox feels really sloppy and the clutch is also very high, im looking to replace the whole lot in one go along with the master and clutch cylinders and maybe lightening the flywheel and fitting an LSD.
Ideally i want to find a second hand gearbox that has had the bushes refurbed and is ready to fit. My car is a 1986 325i coupe, are there any benifits to fitting other gearboxes? which fit? i.e does the 320 gearbox give better acceleration?
Is the flywheel worth skimming? are there people on here that do it?
What ratio slippers should i be looking at?
Sorry for million questions!
Adam :)
Post Fri Aug 26, 2011 3:03 pm
Adam if there is nothing wrong with the box itself other than the linkage being sloppy you can buy all the bits you need to rebuild it from BMW. No point replacing an otherwise good 'box unless of course you can find a known good "Sport" one.
Its a beeyatch of a job as its dirty, fiddly work but its do-able.
You'll probably have to replace the propshaft donut and possibly the centre bearing as well, and new gearbox mounts won't hurt - especially if theyre the originals.
Slave & master cylinders can be had cheaply off ebay - get a braided stainless flexi clutch hose at the same time.
3.64 is the standard diff ratio LSD or open for pre-facelift 325i's I think.
Adams-Sideways
Post Fri Aug 26, 2011 7:58 pm
thanks for the reply mate, when you say its a beeyatch of a job do you mean replacing the linkage bushes or changing the whole gearbox etc?
When its in neutral i can lift the selector straight up about an inch lol is this a good sign that the selector mech is shot to bits? Whats the verdict on fitting short shift whilst im there?
Thanks again
Ad
mrLEE30
Post Fri Aug 26, 2011 8:08 pm
your sloppy change is due to the linkage bushes, easy to change with basic tools at home. Hard job is the gearbox change, as you need to get under the car and lift heavier bits.
short shift at same time is good idea if that is what you want to do, there is a guide on the wiki pages.
to answer your first question the 320 box is the Getrag 240 (as opposed to the 260 found in the 2.5, the 240/250 is the allowable input torque in Nm) and the ratios for 1 2 and 3 are lower than that of the 260 and closer to the "sport" Getrag. 4 and 5 are same ratio. thus yes they will accelerate quicker but require to shift earlier (thus not necessarily faster to a high speed). you will also need the longer prop suited to the shorter 240 box if you change it.
as for diffs then 3.64, 3.73 or 3.91 are "normal" 2.5 ratios. the lower the figure the less acceleration (but read my comment above!!)
I completely refurbed the linkage on my car a couple of months ago - there's a few threads on how to do it.
Did it on Axle stands in a very cramped garage on my own - if you can get access to a lift/ramp/inspection pit it would be a much easier job.
Its less than £100 for all the bits. I didnt bother with a short shift but put it back to "as new" and the transformation is spectacular.
If you have a look at my resto pics thread theres quite a bit in there on how to do it.
**BANNED**
Post Sat Aug 27, 2011 2:00 am
If you are fitting a new clutch and lightening the flywheel,whilst the 'box is out it will be very easy to re-build the linkage.
I have no direct experience of lightened 'flys,but they do allow the engine to pick up speed quicker,and to loose speed more quickly as well...
Youth is wasted on the young.
Adams-Sideways
Post Sun Aug 28, 2011 10:21 pm
sounds like a good mod to me, any chance of finding one already lightened second hand? Or is it best to send mine to a machine shop, just thinking of ways to keep my car on the road many days as possible during the work!
