So I've been looking into making an MPG readout for my iS, but then discovered that some of the higher models of e30 came with a more advanced OBC that does more than just tell the time/temperature - things like MPG, lap timer, code immobiliser etc.
Now, would I be able to buy one of these and swap it over? Would I require extra sensors etc. to make it work? Has anyone done anything like this?
OBC Swap
cee
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
cee
Full list of features here http://www.strictlyeta.net/technical/obcfunctions.html
- **BANNED**
Sounds like you are looking for a 13 button OBC,best off buying a complete 'kit' that includes all the gubbins and wiring loom.
Installing is simply a matter of plugging it all into the car,you will need to remove the heater control panel and the instrument cluster,and the glovebox and it's liner to allow you the thread the loom correctly.
Keep an eye on the 'For Sale' section,or stick a 'wanted' up.
Fleabay may be another place to watch,as well.
Pretty certain that there will be a full fitting guide in the zone Wiki,link button at thr top of every page.
Youth is wasted on the young.
cee
Brilliant, I was hoping it would be an easy swap. Wasn't sure if I'd have all the sensors required etc.
Duke137
adit has a complete kit
cee
Thanks mate. Will get a PM his way now.Duke137 wrote:adit has a complete kit
