Hi guys, im new to E30 ownership, I noticed the other day the temprature gauge will not go any higher than 1/4 and the car smells of fuel as if its running rich, could this be somthing simple like a temp sensor or thermostate not working and telling the ECU to keep it on choke?
Mark
Low temprature reading ???
m8782538
The temp guage sounds ok, even staying at 1/4. The smell of fuel could be a blocked breather pipe from the tank, or possibly a split fuel hose in the engine bay.
Billwill
Are you sure that the previous owner did not remove the thermostat completly?
A lot of thermostats procured from spares shops are stamped as 80 degrees Centigrade but I know that the genuine BMW one for the M40 that I have is stamped at 88 degrees Centigrade...I used to have a too-cool running M40 until I put in the 88 degree part.
Check the fuel hoses in the engine bay with motor running for any leaks as stated above.
What engine?
The temperature gauge on an E30 does not have a linear scale. The centre section only covers a few degrees, so what you describe as the 1/4 mark actually isn't - it's much higher than that.
The usual position of the needle on a six cylinder E30 is slightly past the "quarter" mark, while the four cylinder cars sit with the needle in the middle.
Your car may have had the wrong stat. fitted, or have no stat, at all, but I suspect you're chasing a non existent fault.
3drmark
Thank you for that peeps ....... I got round to taking it apart over the weekend and found that the last owner had indeed removed the thermostat so for now I have a 80 degree item from our old friends at GSF lol, and now the gauge sits slightly higher and the car seems to run slightly better when up to temprature, so thats one problem sorted.
Mark
Mark
xavier
mine did the same. As BillWill said, a previous owner had removed the thermostat. i fitted a new one and now it sits just under half on the gauge all year(once the engine is warm)
My main worry now would be what else the clueless halfwit that previously owned the car has been up to, or has failed to do.
adit
do these people think that the thermostat serves no useful purpose?
[quote="bss325i"]
iceox
lol why would you go through all that fooking about and not just pop another one in? absolute tards
