exhaust smoke
jimbob29
Post Mon Aug 22, 2011 11:09 am
can constant short trips never really using all the gears or the rev range cause the car to smoke a bit once you get the chance to put your foot down??smoke colour is white/grey
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Aug 22, 2011 11:13 am
Most engine wear happens in the first ten minutes, before all the temperatures even out through the engine, so yes, lots of short trips wear out the engine more than a big cruise.
Best thing would be to get a compression test done on all six cylinders. If you only have four cylinders, that's a sign of a much bigger problem.
