Hello,
just fitted a rear diff, what oil do i need for it?
diff oil
Grrrmachine
- E30 Zone Wiki / Team Member
Hypoid oil, 75W90 or 80W90, the choice is yours. If it's a small diff, you'll need just under a litre. if it's a medium diff (for 325) you'll need 1.7 litres.
Bristol_Jer
Unless it is an LSD!
E30_Crazy
Whats different then? The amount needed, or the type of oil? Gonna do mine when I get back from overseas.Bristol_Jer wrote:Unless it is an LSD!
- **BANNED**
Type of oil,run an LSD on standard stuff and it will cease to be an LSD....E30_Crazy wrote:Whats different then? The amount needed, or the type of oil? Gonna do mine when I get back from overseas.Bristol_Jer wrote:Unless it is an LSD!
As I do not run an LSD,I am not sure about the correct grade here,but I am sure a search will pull up a suitable suggestion.
Youth is wasted on the young.
Sanchez
For LSD use Castrol B373 is the only oil ill use for an e30 lsd you can get it from eBay or opie oils.
Duke137
Can you put B373 in an open diff without problems?
- **BANNED**
At a guess,the only thing it will hurt is your wallet....Duke137 wrote:Can you put B373 in an open diff without problems?
Diff. is exactly the same in both, so yes.daimlerman wrote:At a guess,the only thing it will hurt is your wallet....Duke137 wrote:Can you put B373 in an open diff without problems?
