Are these the same for both engines? I'm going to convert a 325i M20 to run on M50 engine management including injectors, MAF and coil on plugs. I've been offered a set up from a 320i,is this the same as a 325? It will be having a remap at some stage so minor differences aren't critical as long as it is basically the same.
Brian
M50 320i/325i injectors
Brian28
No they are different flow rates, ive plenty about if you need a set of M50B25
Brian28
Thanks Dan, it's a long term project so will likely wait for the right running E36 325 donor on fleabay for everything.
Brian
Brian
Best way
