Yo, I'm looking at getting some decent wheels for my 316i
I'm just starting to understand wheel sizes, but for what I understand I need to be looking for 4x100 for stud and diameter.
I came along these alloys
http://www.ebay.co.uk/itm/15-DARE-RS-ST ... 588wt_1139
I think my bottlecap 14" ones are 7J and have an offset of 24mm,
these I noticed have an offset of 35mm and are still 7J, will these fit?
From what I've learnt 7J is the inch width between the outer flange to the inner flange or something like that and offset is the center of the rim to the mounting plate.
Wheels
Grrrmachine
- E30 Zone Wiki / Team Member
If you're looking to spend that sort of money, just get some decent clean BBS. It's only a 316.
Dimension-wise though, offset should be between ET20 and ET35; I run ET12's with no issues though. 7j is the width, and with that offset it MIGHT cause rubbing, but nothing a 5mm spacer wouldn't fix.
Asthenia
Yeah I was thinking about that, good shout man.
I'm struggling to understand that if 7J is the width of the wheel, if the offset is changed from 25 to 35mm how does that not change the width in inches? maybe I'm confusing the matter.
So 7J ET20 - 30 is my aim?
Asthenia
Ignore what I just said, sort of understand now.
Jozi
Those images in the ebay add are for different wheels! Look at the stud patern in relation to the spokes.
This:
vs
This:
vs
chewy320
I noticed the difference in the photos myself, looks a bit shady to me and if your getting reps you should look into other brands or similar styles. Ronal do a similar style wheel for about 500 and they look way better IMO. They are called ronal ls
Jozi
Calibre vintage also do a BBS rep wheel, someone on here has them on their E30 (Aliferrari?).
charlieog1243
i have lenso bsx on my e30 9j at the rear and 7.5 at the front both fit perfect with good offset i have 9j rears for sale atm in mint condition
Bela
Guys, do 9j rears go on without mods to arches???
