E30 Cabrio Window seal/trim
Yes I have used RealOEM I think it is these 12 GASKET LEFT 1 51361922167 $54.02
12 GASKET RIGHT 1 51361922168 $54.02
but it shows them as being part of the front door I am looking for this e30 cabrio outer Quarter Glass seal. I would like confirmation from anyone who has changed these that I have the correct part
..the above is correct and fits on the rear side window ...slides into the black metal attached to the window..2 minute jobvogue666 wrote:Yes I have used RealOEM I think it is these 12 GASKET LEFT 1 51361922167 $54.02
the black metal pieces are expensive
£70 odd each for a saloon
just replaced the weather strips (rubber) on my front door, and as it goes have to go pick up te other side today from bmw, be very careful not to bend it at all as it has a thin metal strip inside, nice job to do mind, looks nice with new rubber
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
part 12 on the above is the only one I can think of that has a "little floppy bit" and runs that way....with the window open ...a pic would help
Part 9 is what I needed 09 DOOR WEATHER STRIP OUTER LEFT 1 51361933751 $32.98
09 DOOR WEATHER STRIP OUTER RIGHT 1 51361933752 $32.98
18€ each from BMW this is the outer seal for side passenger cabrio window. 10 is the black molding that the seal clips to and 8 is the metal clips to connect 9 and 10.
