door swap
chinna
i have an e plate 320 with drivers door central locking problems, there are no central locking parts in the door, where as the rest of the doors do. can i simply find another drivers door, preferably in white, and replace my old one for it all to work? the central locking does not work from the passenger door either?
- **BANNED**
In theory,yes,but,I'm worried that your existing door does not have the c/l bits...,all it needs is the correct solinoid...connected to the latch and held to the door frame by two 8mm bolts,with an electrics plug on it's bottom.
Lot's of c/l problems start with the driver's door,the cheap 'fix' is to un-plug the electrics!
But most issues are down to the c/l relay(found behind and below the radio speaker in the driver's cill)
Youth is wasted on the young.
