electric window mechanism motor swap over
polsta
today i got the electric window mechanism motors out the breaker
one in pass side of my sport is a bit iffy, so thinking just swap the whole thng over, is it easy to do ? any particular way to go about it ? ie keep glass up/down, etc - i have no idea how to go about it tbh
Grrrmachine
- E30 Zone Wiki / Team Member
Annoyingly, the screws that hold the motor assembly to the mechanism face the inside of the door, so you need to unbolt the entire mechanism to swap the motors over, unless you have very nimble fingers. Here's how:
1) Take off the door card, handle and other trimmings.
2) Wind the window all the way down
3) Pop off the rubber window trim on the inside of the door (it's held in place with 4/5 metal spring clamps)
4) Wind the window half way up slowly, and watch. You should see two arms with wheels on the end. One wheel slots into a runner which is bolted onto the skin of the door, the other one fits into a metal runner on the bottom edge of the glass. As the motor turns, it drives round a big toothed semi-circle, which in turn opens or closes these two arms like a pair of scissors. You need to find a way to pop the wheels out of the runners so that you can free up the glass. To do this...
5) Locate the bolts in the bottom-left and -right of the door, which hold the window runners. Loosen them, but make sure the glass is secure. An extra pair of hands, or some wood propped up underneath, will be really useful here.
6) As you undo the bolts, the runners will be free to move. This will allow you to rock and wiggle the glass GENTLY so that you can slip it out of the runners
7) Now you should be able to tilt the glass so that you can get the wheeled arm out from the bottom. It might need a bit of persuasion, but just lift it up and out of the door frame.
8 ) Once the glass is removed, you can undo the two bolts that are holding the mechanism, located bottom-centre and middle of the door skin. The mechanism should just lift out.
9) Three screws will be holding the gearbox (black plastic) to the mechanism, and two bolts holding the motor to the gearbox. Separate the motor from the gearbox, and fit new motor
10) Refitting is the reverse of removal.
That's from memory of doing the same job yesterday.
polsta
thanks for the reply mate
adit has told me- pre facelift (my sport) and facelift (the is breaker i took it from) differ
FEP
Could try keeping the new motor and fitting a new car
Grrrmachine
Could you go back to the breaker and get the whole mechanism? I'm not sure how they differ; RealOEM doesn't list any difference in parts between 1986 and 1990 cars.
Correct - you really need the entire pre-facelift mech and swap it over not just the motor.polsta wrote:thanks for the reply mate
Sell the facelift one on and buy a pre-facelift motor & mech - its not worth fecking around with.
removing the existing mech is fiddly but just take your time.
Its quite obvious where the mech bolts up to the door and you do need to remove the glass - its wiggling the mech out thats the awkward bit.
polsta
ok some confustion here-
i have took the whole mechanism out- un bolted all the bolts, slide the runners off of the metal on bottom of the glass, and dissconected the plug etc and removed the whole lot-motor with the scissor metal mechanism/lifter etc all in one
so is that exact same to swap over ? adit said the "door plug was different" ? or did he mean the actual plug from door-car, and also think he said the actual metal on the glass differed and they cant be used ? but hel have a look if he has any
obviously i dont want to mess it up and find out half way through the job that its different and cant put the new one in, so need to be certain , the one i want to use looks really good and near new aswell
You have the scissor type mech in a pre-facelift car ??
Not the best pic but the mech in a pre-facelift car should look like this :
polsta
NOOOOOOOOOOOOOOOOO !!!
ive taken the mech and motor out of a 318is facelift !!
but the mech in my sport is iffy, so was going to (hoping) to swap it over (not had a look yet or even took the door card off the sport)
so is it totaly different ? ie it looks it
basicly- window goes down ok, but when putting it up it struggles, you have to keep un pressing/pressing the button, and also give it a helping hand on the glass sometimes ?
Yes - the mech ( and glass I think ) in the pre-facelift doors is totally different - the ones above are what you will have in your tech 1.
You may just be able to swap the motor over but it is just as likely to be the mech itself thats worn as a tired motor.
I had to do this on the bronze turd when i first got it.
polsta
im hoping adit has one, a full mech and motor, these motors are good mind, so if i can get a decent mech from him is it easy to still use this motor ? is the little motor plug the same ?
polsta
these are the ones i took out the is ? are they no good then and should sell em ?
They're no good for your tech 1 mate - sell them on and use the money to pay for the earlier type as per my previous pic.
polsta
ok mate, whats about the actual motors ? are they any good to keep and use ? ie from a 1991 is, would be newer motors than ones still attached to pre facelift mechs ? , or doesnt really matter ? how much they worth ? ive put £40 the pair /25 each in the thread is that reasonable ? jsut want what they are worth and have no idea ?
I dont know if the motors are interchangeable.
Unfortunately they mechs/motors dont seem to fetch much secondhand - £15 or maybe a bit more on a good day - theres loads on ebay.
polsta
