Prices and availability please
Looking for genuine BMW parts at discounted prices? Try here!
FEP
Post Sat Aug 06, 2011 11:47 pm
Timing gear gasket - 11 14 1 720 903
Water pump gasket - 11 51 1 722 677
Thermostat housing gasket - 11 53 1 722 692
Thermostat O-ring - 11 53 1 265 084
Sump gasket - 11 13 1 730 234
Rocker cover gasket - 11 12 1 730 229
Sump plug gasket - 07 11 9 963 151
Gearshift parts:
Lock ring - 23 41 1 466 112
Spacer - 23 41 1 200 844
Spring - 23 41 1 200 845
Ball cup upper - 23 41 1 466 110
Bearing - 25 11 1 220 707
Dowel Pin - 23 41 1 466 134
Tension Bush - 25 11 1 203 682
Plastic washer - 25 11 1 434 194
Bearing sleeve, round - 25 11 7 519 669
Bearing, shifting arm - 25 11 1 220 707
Gearshift rod joint - 25 11 7 501 309
O-ring (x2) - 25 11 1 221 243
Spacer - 25 11 1 220 199
Cap - 25 11 1 220 228
Circlip - 07 11 9 932 881
Rubber ring - 23 41 1 666 133
Flat washer - 25 11 1 220 221
Spring washer - 23 41 1 666 122
Gearbox input shaft splines grease - 83 23 9 416 138
All p/n's from BMWFans - sorry if they're wrong!
Cotswoldbmw
Post Tue Aug 09, 2011 4:19 pm
Dear Fep.
Thank you for your enquiry, the price for the items required will be £153.68. This price includes a discount for enquiring on line, VAT and there will be no postage charge to a mainland UK address. If you send me your email address I can let you have a full quote.
Also some of the parts will have to come from Germany so may take up to 7 days to arrive in the UK.
Give us a call to place an order on 01242 257999 and please quote reference number 20003
Regards
Paul.
Paul Webb
Parts Advisor
Cotswold Cheltenham
Main Telephone Number: 01242 257999
Fax Number: 01242 257150
E-mail: partscheltenham@cotswoldgroup.com
Website: www.cotswoldgroup.com
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
