I'm looking to turbocharge my iS over the winter and I've been worried about the 10.5:1 compression ratio.
I've been looking into getting a set of forged pistons made up and have found a company that manufactures pistons from scratch, based on your needs... I was chatting to them yesterday and they want me to send a piston in after I've measured deck height of the crown etc... Rather than just making a shorter version of the piston to lower CR, they work to dish-out the crown and keep the dimensions as close to the original as possible.
"Accralite Pistons is a company specialising in the design and manufacture of small and medium batch quantities of forged pistons in the UK to either existing designs or designs to suit our customer's specific needs. Accralite Pistons are supplied complete with rings, pins and circlips chosen to suit the piston's application and are boxed in weighed sets. Accralite Pistons are constantly investing to give you, the customer, the best-forged piston available whether it be from stock or a purposely designed and manufactured piston. Accralite Pistons heat treatment procedure is based on T6 international specifications that gives reduced stress, maximum hardness and a greater working life span for pistons made for you, the customer."
Their web address is www.accralite.com - Have a look?
Basically, I'm looking at Ԛ£200UK per piston at least, if I get myself a set made up, most of which goes into research and design. - If more than 4 people sign up, we're looking at about halving that, plus the dreaded VAT. That equates to about Ԛ£470UK for professionally researched, designed and manufactured forged pistons down to a suitable compression ratio for turbo applications...
I've asked on a few other BMW Forums I'm a member of too, just to gauge interest.
Cheers folks!
Omi
M42 Forged Pistons... Any interest?
Omi
- Witty custom rank.
...or is it?
m-dtech
- Unapproved Trader caution
youl probly find a company makes them already.
http://www.omegapistons.com/
i have used them before.
