does any one know what the m20 2.5 afr should be running at?
ive just wired up a wideband calibrated it etc but it seems to be running very high the gauge is saying 22.3
its going to be a turbo engine hence the wideband
any ideas ?
thanks
AFR m20 2.5 ???
ross2009
Tommek
With boost you should be on the rich side somewhere around 11.5 - 12. At 22.3 you`re a bit too much on the lean side. Perfect burning point of petrol is at 14.5 and it's a balance of economy and power.
E30 Touring
ross2009
thanks that's what I thought I don't know if it's the gauge or the sensor playing up but I'll try and re calibrate it see if it alters if not I'll plug it in to my laptop see what a live reading is
thanks
thanks
