How hard are the round bushes on the rearward end of the front wishbones to replace?
They look they are a pretty straightforward push in/on? Never done them before so am I missing something?
Any special tools required?
Any tips on removal of old ones and fitting of new ones?
Cheers,
Jim
Wishbone rear bushes?
You need to make a "puller" out of a length of threaded bar, some large washers and a socket big enough to fit over the bush.
Use washing up liquid as a lube to put the new bushes in
Most people simply burn out the old ones with a blowlamp.
Not hard to do at all just take your time
Davies31
Cheers Rob,
Hacksaw then to remove the old outer metal sleeve?
I have a MAPP Torch so I may go down the burning out route.
How do you construct the puller?
- **BANNED**
Good place for polybushes;
Burn the old one's out,but take note of which way round they fit...
Youth is wasted on the young.
