diff or gearbox??
f22raptor1
ive got a whineing noise that i did think was the diff. its worse in the lower gears but makes noise in all..... but the thing thats puzzleing me is when the cars moving if i dip the clutch the noise stops?? any ideas please
- **BANNED**
Propshaft centre bearing?
Youth is wasted on the young.
f22raptor1
the centre bearing is new and was pre-loaded when fitted..... its hard to describe the noise though
m8782538
thrust/ clutch release bearing on its way out? my swift has a similar noise unless the clutch is depressed and i know its the bearing, not sure on a bmw hydraulic clutch though.
f22raptor1
the bearing is a bit noisey but i wouldnt of thought it would make this kind of noise....... im going to try thicker oil in diff a see if it helps if not il try box a see whats what
m8782538
mine is loud enough i have to turn the stereo up in order to drown out the whine, not sorted it out as the clutch still has some life left, will sort it when the clutch is on its last legs.
f22raptor1
my box a diff has got plenty off what seems to be pretty fresh oil in them so looks like you could be right......
