I've just swapped my old m20b25 (no idle probs from this engine and all ancillaries apart from the afm are from the old engine) for another b25, when i first start the car it idles fine but once it reaches temp it starts hunting and after a few minutes dies.
I've tried spraying carb cleaner around possible air leak places and this does nothing, i've cleaned the icv with carb cleaner and that seems to be working ok.
I've not changed the blue temp sensor, could this be anything to do with it?
What else could i try?
Hunting and cutting out when warm
adz79
Now sorted, it was the TPS. Cleaned and a hole drilled as suggested by Mr Moore and the old girl runs lovely again.
Thanks again to the search function on the zone for helping me fix my car for free.
