wiring pinouts M60 - E30
Driftben
Post Wed Jul 27, 2011 11:26 am
has anyone done a sort of diagram of intergrating these to looms together?
im just about to tackle the wiring side of things and was wondering if you are able to use a M60 auto ECU/loom with a manual M60?
thanks
ben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
E30SPDFRK
Post Wed Jul 27, 2011 6:32 pm
Don't have the pinouts with me but I think I still have them. You can use the auto loom fine, there are a few wires and the transmission computer that just won't be used.
-Byron
SHAZ325iSPORT
Post Wed Jul 27, 2011 9:02 pm
im using the same loom so a diagram would be very helpful.
cheers
Driftben
Post Wed Jul 27, 2011 10:45 pm
its all down to you now Byron haha. the pressure is on. how are you anyway mate?
thanks
ben
6pot wilwoods front
4pot Porsche rear
E30SPDFRK
Post Thu Jul 28, 2011 9:00 pm
I haven't been home yet to look for my old scribbles unfortunatly haha. When I was making them though I found an e36 c101 chart and compared it to my harness and they lined up almost perfectly. There were only like 3 or 4 wires that were different colors/in different locations. I can't seem to find that chart now though :mad:
-Byron
E30SPDFRK
Post Thu Jul 28, 2011 9:04 pm
e30.de has one as well, but I don't think it worked out very well for me. It's been so long since I was doing this. Worth a try though.
vom Pin V8
Kabelfarbe
Funktion
Hinweise zum Adapterkabelbaum
zum Pin am E30
1
weiss
Ölniveau statisch
mit 0,75 weiss 2
2
blau weiss
Ölniveau dynamisch
mit 0,75 blauweiss
10
3
rotblau 1,5
ABS Versorgung
nur bei E30 ab 89 mit ABS
20
4
schwarzgrÃan
weglassen
5
schwarzweiss
weglassen
6
schwarzblau
weglassen
7
schwarzgelb
weglassen
8
weiss
weglassen
9
leer
weglassen
10
leer
weglassen
11
braungelb
Ferntermometer
mit 0,75 braungelb
4
12
gelbweiss
Ferntermometer Masse weglassen + Geber vom E30 verbauen
13
grÃanlila 1.0
Benzinpumpe
mit 1.5 grÃanlila
13
14
schwarz weiss
Geschwindigkeitssignal
zum Tacho weisser Stecker B12
B12 am Tacho
15
grÃanschwarz 1.5
Entlastungsrelais
mit 1,5 grÃanschwarz
15
16
braunlila
Diagnose Fahrzeug Weckleitung
weglassen
17
weisslila
Diagnose Fahrzeug Datenleitung weglassen
18
schwarzgelb 1.5
Anlasser Klemme 50
mit 1.5qmm und gelbschwarz
18
19
weissgrÃan
SI Aanzeige
mit 0,5 weissgrÃan
11
20
schwarz
Drehzahlmesser
mit 0,75 schwarz
9
21
grÃan 2.5
ZÃandplus
mit 2.5qmm grÃan
7
22
grÃanweiss 1.0
Versorgung Diagnosestecker
mit 1.0 grÃanweiss
6
23
braungrÃan
Öldruck
mit 0,75 braungrÃan
5
24
weissschwarz
Verbrauchsanzeige
weglassen, geht im E30 eh nicht
8
25
blau Lichtmaschine
mit 0,75 blau
1
Apparently their chart doesn't copy over as well as I had planned
-Byron
Driftben
Post Thu Jul 28, 2011 11:03 pm
Lovely thanks Byron :D
a engine conversion isnt a engine conversion without scribbles haha
well iv translated that chart but its not too clear on some bits? i dont supose you have some pics of your harness with the modfications do you mate? :cool:
6pot wilwoods front
4pot Porsche rear
Driftben
Post Thu Jul 28, 2011 11:12 pm
how does this look? if its right then it should be sticky :cool:
http://e30v8.plainsimple.dk/wiring.php
6pot wilwoods front
4pot Porsche rear
garagistic
Post Thu Jul 19, 2012 8:43 pm
Maybe our guide can help a bit?
http://garagistic.com/index.php?page=e30-m60-wiring
This is how our m60 was wired. Now going m62!
FormerMember
Post Mon Jul 23, 2012 10:09 am
My notes on my both V8 projects - with manual and with automatic transmission - can be found here; http://peruna.fi/~jonsku/E30_V8/ (the third .pdf is the radiator drawing).
They WILL NOT work on each and every swap!
I still highly recommend that anyone doing the swap should make their own pin-outs based on real wiring schematics that can be found on the 'net. It makes you understand the whole engine management much better..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
