Car cuts out while running
SeymourCake
A very annoying incident happened today with my E30. I was driving and suddenly all power cut out while I was on the move. Luckily it happened just as I entered a car park. Would of been a headache if it was a busy road.
Every time I would start it, it would die out straight away soon as it tried to idle. So therefore it was not idling at all, unless I had my foot on the throttle, as soon as I would let go of the throttle, the revs would drop all the way and it would completely cut out.
I checked and sprayed the ICV with WD40, checked AFM, distributor cap, few other things but did not really have a clue what it was. Suddenly, TWO hours later, I started it again, and it idled perfectly. Everything was back to normal as if nothing happened. The car held idle and I drove home perfectly normal.
What could the issue be here? I will not be driving it again until this problem is fixed, dread to think of the worst places it could happen again.
edit:
one more point to add, the car cut out when i took a sharp turn.
edit:
SeymourCake
- BadMoonRising
Had something similar on my 320. It's pretty scary coming off a busy roundabout and the car dies.
First time was faulty AFM, second was Temp Sensor.
SeymourCake
grantorino
My 86 325ES did this about a month ago. After replacing the main relay, it still did it. Turned out to be a faulty ICV. cleaning it with WD40 leaves a residue. I would use brake cleaner or throttle body cleaner. Mine would quit at very light throttle around 1100 RPM and coming to a stop. i didn't trust my ICV and got another. Its been faultless since.
1986 325 ES stick shift 137,000 miles, 1973 Mercedes 280C
HairyScreech
do check your fuel pump isnt stopping, they can start and stop at random when they are on there way out, you only have to listen for it pumping when turning the car over
SeymourCake
SeymourCake
- Brianmoooore
What, exactly, does the rev. counter do when the engine cuts? Drop like a stone, or die as the engine dies?
I had this about 6 weeks ago...kept totally cutting out when on the move ..ticked over ok..it would catch again and go for a bit then do it again ..tried everything ..in the end I suspected dirty fuel...filled her up again and it went away never to return..
SeymourCake
- Brianmoooore
In that case it's far more likely to be a fuel supply fault than an ignition one.SeymourCake wrote:The revs dies as the engine dies..Brianmoooore wrote:What, exactly, does the rev. counter do when the engine cuts? Drop like a stone, or die as the engine dies?
Fuel pump is the prime suspect.
SeymourCake
- Brianmoooore
Difficult to test something that only fails occasionally, but the next step should ideally to check whether power fails to the pump, rather than the pump just stops.SeymourCake wrote:Thanks Brian, what is the best method to test the fuel pump?
You need to connect a bulb or LED across the pump terminals, under the rear seat, position the bulb somewhere where you can see it while driving, and see if the bulb goes out before or after the car fails.
SeymourCake
- Brianmoooore
The fuel pump is in the tank, and is reached by removing an access panel under the rear seat.
