Turbo size
jimmyspeed
Post Sat Jul 23, 2011 10:17 am
R34 OEM Turbos
I have found two of these going cheap and and would like to rebuild one and get my recently layed up 320 project on the go
the spec is below
Part# 14411 AA300, Comp Housing is a T3 with a C100wheel. A/R is .53. Turbine housing is a T25 w/GT25 wheel, A/R is .48 Max BHP of airflow is 225. These turbos will break after prolonged use over 14.7psi as they are ceramic
do you think one would be big enough on my engine - i reckon it will spool up nicely - but will it choke the top end ?
any help much appreciated
Andy325i
Post Sat Jul 23, 2011 10:31 am
Would have thought it would be fine for a 320(?) but the reason the skyline boys change them is because they can't load them too much. My T2 runs 20psi all day long.
Andy
jimmyspeed
Post Sat Jul 23, 2011 11:06 am
cheers andy - its an m20b20 so should be fine with the low boost levels
I dont think i would put more than 10psi through it any way so hopefully the blades should hold out
what spec is your t2 and whats it boosting ?
