Trailing arm dust shield - replacing without removing hub?
Jozi
Post Fri Jul 22, 2011 4:57 pm
Someone (me) just pressed the rear hubs into brand new bearings only to realise the dust shield for the rear disc should have gone on first :cry:
Anyone fitted one before without removing the bearing or hub? Was thinking I can fit it either by cutting down through the shield and twisting it or grinding out a section of the middle so it fits around the hub. Any other options?
BadDave
Post Fri Jul 22, 2011 6:36 pm
You can get away with just cutting a slot in it and manouvering it into place,then spot welding it afterwards.
HTH
Post Fri Jul 22, 2011 7:21 pm
As above. Done several like this.
Don't forget that the handbrakes shoes locate against the "dust shield", so be careful not to have any lumps of weld where they sit.
Jozi
Post Fri Jul 22, 2011 7:46 pm
I'll get the angle grinder out so!
I'm expecting this to be a little more hassle than welding on the car body with it being so thin.
