320 to 325 engine swap how hard/easy
cherryredbenj11
Post Thu Jul 21, 2011 2:40 pm
I'm looking to swap my m20 in my 320 ise with a 325i e30 engine. How hard/easy is it and what parts will i need. Is it better to buy just an engine or the full car.
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Jul 21, 2011 3:41 pm
For ease of installation, the gearbox comes out and goes back in with the engine; trying to put just the engine in is a nightmare.
And you'll also want a different diff, because the 4.10 or 4.27 diff you have will be useless with a 325; it'll make first gear utterly redundant. And if you have a diff from a 325, it'll need different output flanges for the drive shafts, and the prop will need adjusting too because 325 diffs are medium case, while 320 diffs are small case.
So, with all the mechanical stuff being swapped, you'll also need the ECU for the 325; it's the same circuitry as your 320 one, but it has a different chip inside. You might also want the oil cooler for a 325 as well, plus the AFM and throttle body. All other stuff; loom, exhaust, sensors, ICV, radiator, that's all the same as your 320 stuff AFAIK.
Based on that, you might want to find an entire donor vehicle rather than shopping for parts individually.
cherryredbenj11
Post Thu Jul 21, 2011 11:24 pm
thankyou for that. I was thinking of buying a donor car. So you would say engine and box out of my 320 and the 325 will fit straight in no problem? Then add the diff etc.
Ajsingh
Post Thu Jul 21, 2011 11:34 pm
U dont need an oil cooler as todays oils can cope with high engine temps and oil coolers can leak.. 325 engine, gearbox, prop, diff, ecu, air flow meter. While u got the donor car, replace the front 320i struts for the 51mm ones in the 325.. Wiring is the same so its plug and play! And thats about it i think...
E30 Crazy!
