m20 mixture screw
lamby
Post Fri Jul 15, 2011 9:25 pm
i,ve just found the mixture screw has been turned all the way down,the car is new to me as i,m fixing (trying) it up,car is missing every now and then and is fumey when driving.now is it best to take it to a garage and set it up on analyser or undo the screw and and turn down till it smooths out. :x
Post Sat Jul 16, 2011 12:38 am
Never buy a car from an idiot!
Screw can only be set properly using a gas analyser, but before you can do that, everything else needs to be right. Catch 22.
lamby
Post Sun Jul 17, 2011 9:03 am
thought as much it,s just i,m the idiot for buying it! have changed blue sensor redone all hoses,set tps and need a icv as mine is running rough.is that all i,ll need to do before having set on analyser?oils filters done and valve gaps and numerous other bodged findings! electric ariel works though 8O
Post Sun Jul 17, 2011 9:41 am
£60 to have the injectors rebuilt (see traders' section) and you'll hopefully be good to go.
lamby
Post Sun Jul 17, 2011 11:32 am
ok will do.thanks for help so far,think i,ll be a regular!
