electrical contact query - brian mooore??
e30lou
Post Thu Jul 14, 2011 9:54 pm
I noticed when I was changing my license assembly light that the connections had some whitish/blue deposits on them. also the assembly I removed had it covered over one of the metal connections. what sort of corrosion is this and how can it affect the connection?
rrs
Post Fri Jul 15, 2011 9:22 am
Sounds very similar to what I found with mine, its deposites left by evapourating moisture I would say. Clean the contacts with some like emery paper then reassemble smearing some copper grease on the contacts first, should help.
