Hi everyone, iv got a chance of a e36 325 just a few quick questions that im not to sure on
* brake servo ??? do you need to chance it or can u keep the old one ???
* gearbox ??? can i use the 325 ?? if so what prop?
* is there anything e on the car
i need to find from scrap yard to get it in n what can i us of the car (what i mean, is there everything i need to make it fit on the 325?)
thanks[/code]
HELP QUICK FIRE QUESTIONS LOL
Robbo-80
Hi answer to you're first question is yes, you'll need to purchase a Clio Brake Servo from any plastic winged scrapper.
You can use the 325 box, but need to adjust the gearbox rod as it sits at an angle once bolted upto the Engine. You get away with using the 325 Prop also.
Make sure you get the ECU, EWS & Keys from the Donar car, as without these the Engine won't start. Take as much with the engine as possible i.e Exhaust Manifolds, Loom etc.
fulllockn2smokingtyres
thanks for that.
iv kinda got an idea but just dont want to jump in
im a mechanic by trade so im more than capable
so rip everything out or the e36:
*does the engine mount bolt straight to e30 cross member?
*does the gearbox just bolt staight on?
*is there any modifications i need to Know about before i start striping lol?
* and does the servo just bolt straight on?
