......... blue 15a both! I felt duty bound to inform the owners that a horrible fiery doom awaited them.
I would have added this to the previous thread, but of course it was f*cking locked just as it was getting interesting.
Okay. When it's reopened, perhaps you could lock this thread? Despite my sarcasm, it's certainly food for thought. Why do so many have the fatter fuse?Brianmoooore wrote:I thank you for carrying on my mission, Andrew. The original thread will be unlocked in due course.
That's the set up that will cook the wiring if the fuel pump jams!Ranchero wrote:Out of curiosity I checked my fusebox earlier. Blue 15A in slot 11.
Car is a 1990 318is running on LPG for the last 10 years.
Aren't you a good boy. Have a sweetie.daimlerman wrote:Perhaps I should point out that I had no imput into the original thread,but STILL got slagged off by Barryboy!
Both of my E30's carry 7.5 amp fuses for the fuel pump.
No harm in changing it I suppose.Brianmoooore wrote:That's the set up that will cook the wiring if the fuel pump jams!Ranchero wrote:Out of curiosity I checked my fusebox earlier. Blue 15A in slot 11.
Do you have to Daniel. Play nicely or I'll bring out the foam at the next bbb meetJhonno wrote:Aren't you a good boy. Have a sweetie.daimlerman wrote:Perhaps I should point out that I had no imput into the original thread,but STILL got slagged off by Barryboy!
He hardly slagged you off.. I am sure you'd have come along in due course to stick your oar in..
You had the high ground there for a couple of hours Malc.daimlerman wrote:Perhaps I should point out that I had no imput into the original thread,but STILL got slagged off by Barryboy!
you are all welcome to try and take the P out of me as I will soon be in Spain drinking Coronita in an apartment overlooking a pool and Nikki Beach, with a nice relaxing golf course a few strides to the rear, thus i will not really care.....but be warned anyway, please lets keep it civil folksmagpie wrote:as mudmrLEE30 wrote:
Clear?
Already bee said Malcolm. On the other post.daimlerman wrote:Been looking at Bentley and Haynes this morning.
Bentley states 15a fuse for 11 for '84-'87 and 7.5a for '88-90....
so have I on the basis that if the smaller fuse blows constantly then some investigation of the pump etc is required, if you leave the larger fuse in then you obviously have a higher chance of a loom threatening problem.KimH wrote:I, for one, am grateful for any advice that helps me keep my Touring going.
And in response to these threads I have replaced my 15A fuse 11with a 7.5A one on the grounds that it cannot do any harm.
emergency medical technicianFelix79 wrote:What is an EMT?
great post!! couldn't agree more.capri_rob wrote:Checked the handbook that came with the car ( Silver book dated 1987 ) Covers facelift & 325i touring models - states that Fuse 11 should be 7.5a
Checked the car - fuse 11 is 7.5a
My 2p's worth
I can't honestly see genuine BMW Tech's replacing this fuse with a 15a version to "cure" a blowing fuse issue.
Anybody with even the most rudimentary knowledge of electrics ( even me ! ) knows that the cure for a blowing fuse is not simply to fit a bigger one - and at the prices BMW charge for servicing/repairs their Techs should know that better than anyone.
Why would any BMW dealer "fix" a blowing fuel pump fuse in this way when they could make much more money by charging for a new pump ?
The potential for comeback and potential legal issues on any BMW dealer who's fitting of a higher rated fuse to cure a problem which subseqently did cause a fire is too great.
IMO Any cars which don't have the correct fuse fitted to tally with the handbook that came with the car are far more likely to have been changed/bodged by amateur mechanics than BMW dealers.
As for why "so many" cars have the wrong fuse fitted thats anyones guess - the fact that most of these turds are well over 20 Years old with multiple amatuer mechanic owners under their belts surely says something ! ( and is the handful of cars at the pod vs the number of E30's in daily use really a fair sample to look at - bearing in mind the cars at the Pod are pretty much ALL owned by home mechanics of varying ability ? )
If you have an unmodified car and are in any doubt go with what the handbook that came with the car tells you.
As for the mud-slinging not really a fan of the bad vibes the last couple of days - I've been given solid, accurate advice by Barry, Brian, Willnz and loads of other zoners countless times over the past few years - why is it so hard for all these people that love the E30 to get along![]()
Banter is great fun. Personal attacks are not.
