Help Needed! Tea, Biscuits and Petrol Provided!
tom325sport
Hi all.
I'm having so many problems getting the rear axle off my cab. Link here... http://www.e30zone.net/modules.php?name ... t=#2201083
I've taken everything I need to off, but still it refuses to move!
Is there someone who knows what there doing willing to come give me a hand? I know its a long shot but I have spent 3 long days now to get it dropped and I'm losing the will to live.
Tea/biscuits/beer/your petrol money etc will be provided.
Hope someone can help? Cheers!
- Homo Hair
Have you tried swinging the trailing arms down?
Or a 3/8ths extension up the middle and wiggle.. Lots. Back and forth to work it loose.
tom325sport
Yep, I've swung them down, held them up with stands, I've supported the diff with a jack to take the weight.
I've tried wiggling a piece of steel up through the hole but it's not that long. Shall I try a longer piece or as you say a 3/8th bar in there?
schnaarf
I've just had the same issue dropping one side of my beam down.
Put something into the hole and give a couple of big smacks. I used a bent t-bar which wedged in nicely and belted that. Once its dislodged you 'll be able to give it a couple of wobbles and it'll drop. Watch out though as the beam will drop down with force if not supported properly.
tom325sport
OK thanks! It sounds like I need a bigger bar then. How far up should it go?
schnaarf
if the bar is as wide as the hole, don't go too far up; maybe 3 inches. If its narrower than the hole then its not so critical.
tom325sport
OK Thanks. Can i use the bolt that came out the top to put in from underneath and smack that? And then replace them?
schnaarf
those bolts may not be designed for that kind of stress and may snap. If you're replacing them then may as well give it a go!
They're not always this difficult. Last one I changed held on just until I walked under it, then fell off under its own weight, giving me a good smack on the head!
The bar from the tee handle of my 1/2" socket set is just the right size to up these bushes, and is just the right length to get some good leverage when hit with a larger hammer.
schnaarf
You got it easy, Brian. I'm probably going to resort to drilling my bolt out now due to some nice galvanic corrosion. This is what the inside of a bit of the alloy looks like and probably why i cant get the bolt out:
A large, deep hole saw will deal with the rubber and allow the subframe to drop away. Ideally you need two hole saws; one just bigger than the aluminium bush, and the other just smaller than the outer sleeve.
- Homo Hair
No I wouldn't.. It needs leverage with a long bar rather than impact force.tom325sport wrote:OK Thanks. Can i use the bolt that came out the top to put in from underneath and smack that? And then replace them?
tom325sport
Thanks so much for the help! I'll be buying something to fit this at the weekend and hopefully i'll have more joy!!
tom325sport
Finally after hours of hitting and swearing the rear axle gave in!! Thanks to all for the advise...much appreciated! Think I will need new drive shafts and new trailing arms so I am on the hunt for these. Tomorrow, new bushes from BMW!!
