What am I doing wrong with the thermostat o-ring?
clydesdale
Am I supposed to fit the T-stat into the slit that is in the o-ring? The t-stat fits perfectly into the housing and will not fit with the o-ring installed as described. This o-ring is not the typical solid looking "o-ring". It has a slit all the way around it and the thermostat is able to go inside this slit, so that some of the o-ring is behind the t-stat and some in front. Imagine a thick o-ring with a slit all around it and the t-stat seems to appear to fit into that slit. Why else would they have the slit?
Alburglar
Doesn't sound like the right part at all I'm afraid.
M42 - rightness! with proper 4.27 LSD
Ranchero
Sounds frustrating. Can you supply photos?
clydesdale
I will take pics tomorrow. This is on an M20 325I, thanks.
mattycoops43
Thermostats tend to be supplied for more than one engine and come with a mixture of oring's and gaskets etc. I think that is a different type of gasket for a different vehicle. The thermostat is probably right, does it have a gasket in the box as well (paper)?
1990 325i se "weinrot"-How did they know?
clydesdale
No paper gasket, just the square profile o-ring with the slit in the center.
clydesdale
The gasket was incorrect. I now have the proper o-ring, Thanks.
