Variability in engine temp during normal driving?
George
Post Mon Jul 11, 2011 12:05 pm
This could just be paranoia on my part as I'm using the E30 for a Euro drive in the next couple of weeks.
How much variability in engine temp should one expect during normal use? If completely unstressed, (down a hill/no throttle) mine will sit at the first marking. In traffic it'll go up to mid way. I then get 'the fear' and feel it necessary to turn on the heater/fan.
I remember Brian Mooooooooore stating that the sensor is very sensitive. Is the difference between the first marking and the midway point much? I don't believe it is an issue for concern but my e36 sits bang in the middle and never moves!
m8782538
Post Mon Jul 11, 2011 12:30 pm
don't worry unless it starts to creap up, or suddenly shoot up to hot in a very short space of time.
Post Mon Jul 11, 2011 12:31 pm
The only time the gauge should move is to go up a little when stopped or nearly stopped in traffic, and if the ignition is turned on again shortly after the engine has stopped.
If it goes up when the engine is worked hard, then the cooling is inadequate (usually radiator or just possibly pump), or if it goes down when the engine is worked lightly, than the thermostat is suspect.
If the gauge jumps about quickly, then the nut on the back of the cluster is loose.
No need to turn the fan on at half gauge. Start worrying when it's close to the red.
George
Post Mon Jul 11, 2011 12:35 pm
Brianmoooore wrote:The only time the gauge should move is to go up a little when stopped or nearly stopped in traffic, and if the ignition is turned on again shortly after the engine has stopped.
Thanks for the info. :)
The increase is typically from the midpoint of the first mark and the centre, up to the centre itself (if that makes sense). Not a huge amount but as ever with E30s, 'the fear' is strong.
Iirc, there is a blue and brown thermostat. Which could be the one with issues?
Post Mon Jul 11, 2011 12:40 pm
From your description, all sounds normal. Keep your nerve a little longer, and ensure that the viscous fan coupling locks up. If the temp. continues to climb, and the coupling doesn't lock, then it's the chief suspect.
Brown sensor is for the gauge, but nothing you've said suggests there's anything wrong with it!
George
Post Mon Jul 11, 2011 12:49 pm
Brianmoooore wrote:From your description, all sounds normal. Keep your nerve a little longer, and ensure that the viscous fan coupling locks up. If the temp. continues to climb, and the coupling doesn't lock, then it's the chief suspect.
Thanks for the reassurance Brian. Suffice to say driving an E30 has made me question/be suspicious of everything! :o
