The HT leads and coil are fine. After pulling the spark plugs out I have found that spark plug number 1 has a strong smell of fuel coming from it.
I did a compression test and they all came out around 170-180psi.
Im thinking that there a problem with the fuel injector on cylinder 1?
Can these be ultrasonically cleaned or do i need a new one?
**Update**
Went to start the car today and after about 30secs it started to puff out blue smoke. The higher the revs the more smoke given out. Im not sure if these are related problems?
Im going to do another compression test tomorrow
Heres 2 videos:
Any more advice would be appreciated,
