Does any one know what type of sensor the M50b25 non vanos uses,Zirconia or titania?
Been reading up a bit and it seems if the wiring has a red or yellow wire then it could be a titania type.Because some one has chopped off the plug for the lambda i`m unsure what type of sensor i should fit.
The wires that are showing where the plug got cut off are Black,Yellow,Brown and Green/Blue can anyone tell me which wire does what ie signal and heater etc?
Lambda sensors
