Subframe nightmare
schnaarf
Post Sat Jul 09, 2011 3:38 pm
Read Pimpmobils thread on his success of changing subframe bushes wilst subframe insitu. Thought I'd have a go
Got the two lower push rod arm things off easily.
Right had side - cant get the bolt out. Tried a sledge hammer and jacking it up on the bolt: no movement at all.
Left hand side - bolt came out easily with a few taps. Whey I thought. Nope. The top aluminium bit of the bush is stuck in so it won't come down. No movement in it at all
So, I'm stuck. Half the inner aluminium bit has snapped on the right side so now can't use the car.
Anyone any ideas on what the **** I can do now?
Any suggestions appreciated.
Thanks!
Annoyed of Hamble.
**BANNED**
Post Sat Jul 09, 2011 6:59 pm
Horrible job,fine attempting this on a project car that you can walk away from when things go wrong,but on a daily that you need tomorrow,pay a specialist £100/£150!
Bit late for you now,though.
I would guess that the pin that is stuck is perhaps not square,rear beam hanging on it? Try a jack under the other side to line it up.
A hole saw to slice the remaining rubber out may help to free the pin off,or belting the bush holder with your hammer may help free it,if nothing else it is very satisfying to hurt the offending part!
The stuck alloy part of the bush should come free with suitable force applied to it,a socket extension bar may help here.
May also help to remove the diff and trailing arms,lets the beam sit square to it's mount.
Youth is wasted on the young.
schnaarf
Post Sat Jul 09, 2011 7:16 pm
A bit of the aluminium surrounding the pin had snapped off and fell out when I took the bottom bit off. Its about 3 inches long and goes to a point. The inside of this bit has completely corroded the bolt by the looks of it which is presumably why it's stuck! There is a bit of flex in the bolt when putting a bit of force on it but it hasn't budged upwards
On the other side where the bolt came out easily the aluminium rod seems completely jammed! I've tried smacking it with a 4lb er hoping to snap it so I could drop the beam a bit and cut/ drill out the bit in the body. Also tried putting an extension in there and smacking that but nothing! If I look down the hole I cant see a gap between it and whatever it butts up to.
When smacking the stuck bolt, the beam was level. Ive given it some right brute force and the end of the stuck aluminium is ****** now!
Well it was my daily car! Looks like I'm on the bike this week
schnaarf
Post Mon Jul 11, 2011 11:09 pm
Got the left side out and replaced ok after some absolute abuse.
Right hand side with the stuck bolt is not moving whatever I try so, even though I hate to admit it, the bastard piece of metal seems to have beaten me. A slice of the alu around the bolt must have snapped off ages ago (but was still in situ) and as such we've got galvanic corrosion all the way up around the crack and therefore its pretty much bonded.
I hate giving up but have to return the bush tool on Thursday to pimpmobil. I've one more idea involving a jigsaw if it'll fit. Minor issue is I don't have one.
schnaarf
Post Tue Jul 12, 2011 10:27 pm
this is what the inside of the alu looks like and why the bolt wont come out:
Post Tue Jul 12, 2011 11:56 pm
The bolt will come out if you hit it hard enough! Make sure you've got a large piece of cloth or mat lying across the top of it inside the car, or when it does go it will rattle around the inside of the car like shrapnel.
Kieran_n22
Post Wed Jul 13, 2011 12:19 am
I did this job 2 weeks ago it's a bastard! The subframe wouldn't drop but I managed to drop it but couldn't get the bushes to move within 30 mins so took the whole subframe out and pissed WD40 all over them got the blow torch and let them burn out then it was matter of 2 mins before they came out :D
martijn76
Post Wed Jul 13, 2011 1:08 am
Have you tried hitting it after you heat it with a burner/heater?
I had the same problem, after firing the sucker up I could get it out, don't forget to place something on top of the bolt, inside the car(if you hit it too hard it will hit the roof :D )
schnaarf
Post Wed Jul 13, 2011 10:14 am
I will try some heat but its dangerously close to the petrol tank! Getting the bush out wont be a problem as its completely separated from the inner alu ring and I've borrowed a tool.
I've been at it with a 7lb sledge hammer for 4 days now and it hasn't moved. Trying a jigsaw and drill tonight. Maybe some heat too.
MattCyclone
Post Wed Jul 13, 2011 1:58 pm
You managed to get this moving at all?
No extra advice to add but I am away for a week next week so more than happy to leave you some tools etc if you need then!
schnaarf
Post Wed Jul 13, 2011 3:32 pm
thanks Matt. I'm probably ok but you're welcome to take your frustration out on it! Need to get the aluminium bush out tonight as have to somehow return the tool tomorrow. Borrowed a jigsaw which will hopefully do some damage.
You dont have a small blow torch do you?
MattCyclone
Post Wed Jul 13, 2011 4:08 pm
I don't unfortunately, and the bloke I know with one is away for the week! Sorry Steve!
Just had a quick look and if you know anyone in Soton then a small one is £21 at Machine Mart, I would bring it to you tonight but I am off to Bournemouth tonight...
Good luck with it, makes a real difference when its done...
Did you get the fuel line issue sorted?
schnaarf
Post Wed Jul 13, 2011 4:13 pm
Thanks for looking Matt.
Yep, fuel line in the engine bay took about 5 minutes!
schnaarf
Post Wed Jul 13, 2011 7:16 pm
It's moved 2mm! Time for a celebratory bottle of Hobgoblin
MattCyclone
Post Thu Jul 14, 2011 7:56 am
Brute force (and ignorance) I assume :) Hope you managed to get the rest out and the bushes swapped!
When you're done could you ping me a PM with the amount of fuel hose you used, thinking I should do mine anyway...
schnaarf
Post Thu Jul 14, 2011 8:18 am
Update: still jammed. Got the bolt up as far up as the bottom of the alu bush and it was still requiring some smashing. Now I can't hit it any further
Only thing to do now is either grind off the alu bush or drill out the head?
Post Thu Jul 14, 2011 9:14 am
If you've moved the bolt up at all, spray WD40 liberally around, including some down the hole from the top, then bash it down again from inside the car.
As with any fastener that's being difficult, the technique is to move it over and back, undo and tighten, adding penetrant all the time, and gradually the fluid will be drawn in, and the ba**ard will admit defeat.
schnaarf
Post Fri Jul 15, 2011 1:27 pm
Spent 3 hours last night doing just that. Now the aluminium bush moves freely until something inside it hits the thread then stops. Having my weight on mole grips pulling it down and twisting worked but there was that much friction I couldn't touch the bush or bolt due to the heat! Only another couple of inches until its off.
Borrowed an angle grinder today so hopefully do some damage with that later.
schnaarf
Post Thu Aug 04, 2011 1:03 pm
Did it all in the end. Pulled the aluminium bush down a bit grind it off, repeat. This it what it looked like:
Post Fri Aug 05, 2011 3:48 pm
i'm doing this soon :( you need a new bolt m8 8O
