316i running problems when hot.
adamDOT
Wed Jul 06, 2011 2:39 pm
i have a 316i it runs fine but after a while of driving or when the enine has been running when u accelerate it cuts out for a second then kicks back in again. it happends in all gears but once its done it once it seems to clear then be ok throughout that gear untill the change.
i have changed the spark plugs, leads and rotar arm.
has anyone else had this problem and could help much appreciated.
m8782538
Wed Jul 06, 2011 2:57 pm
fuel issue i am guessing, fuel pressure regulator, probably be at a certain point in the rev range there is a lack of pressure from the regulator into the fuel rail. If it happened all the time could be the blue sensor or possibly dizzy.
Does this happen everytime its driven and gets up to temp?
adamDOT
Wed Jul 06, 2011 3:03 pm
have changed the blue sensor along with a brown one as i had problems with my temp gauge but that is now sorted. yes everytime its hot, haven't changed the dizzy but a few people have said that. its worse in 4th gear untill you let off the throttle then back on. :?
nickpye68
Wed Jul 06, 2011 9:05 pm
I've had a similar problem with a 325 touring,willi [from nz i think],reckons it's the main relay,my post reads''engine misfire'' for more details.I've checked all the relays in the main box under the bonnet and all are clean,all connections clean,but still same problem,i'm no electrician so havent done any testing on the relays themselves,i'm thinking along the lines of m8782538 that it's fuel pressure regulator or fuel supply issue,possibly injectors,thats my next port of call,keep posting and let us know if you find the problem.cheers.nick
m8782538
Thu Jul 07, 2011 8:30 am
Possibly a relay,just because it looks ok, doesn't mean it's not knackered. possibly worth swopping with one you know works to test it.
I had an issue with mine not starting, cleaned up the fuel pipes from the fuel pipe back to the fuel pressure regulator, cleaned that too, next turn it started, no idea why. Remember if you are testing the pressure it should be 3 bar.
