m20 2.5 block
lowrider1
im getting like a clunk noise comming from block what can it be, i think it may be on its way out ..... do i replace this with a new engine or can i sort out the block?
Mikey_Boy
Could be death rattle of many kinds! If it's coming from the block then it's probably a big end bearing gone...
You can replace with a short engine - depends on the damage - more details please!
Does the problem occur when:
Cold or hot or both?
On start up?
Low or high revs?
Low or high throttle opening?
Good luck...
Mike
On start up?
Low or high revs?
Good luck...
Mike
lowrider1
mainly occurs on start up when cold
low revs
high throttle open
low revs
high throttle open
