Brake Light Warning On Check Panel
mustard
Post Tue Oct 18, 2005 8:06 pm
On occasions I get the warning light lit on the check panel whilst driving, but when I physically look at the rear of the car they are functioning fine.
Is this a common problem, any connections etc I should look at?
kam-325i
Post Tue Oct 18, 2005 8:27 pm
mustard wrote:On occasions I get the warning light lit on the check panel whilst driving, but when I physically look at the rear of the car they are functioning fine.
I used to have the same problem on my old 320i, it turned out to be the electrics installed with the tow bar causing the problem.
Nick325
Post Tue Oct 18, 2005 8:38 pm
I had this problem after i'd fitted some Mtech pedals.
Try adjusting the break pedal light switch,its located under the pedal itself.
And when i say `adjust`i mean physically bend the mounting!
Its a bit trial and error.
skidlidsid
Post Tue Oct 18, 2005 9:09 pm
I had the same problem, sorted it with fitting a new brake light switch.
1990 320i Auto Sterling Silver
Post Tue Oct 18, 2005 9:28 pm
Brake light switch is a possibility, but not usually the cause on an E30.
More likely to be the connections to the lamps in the rear clusters being a bit tarnished. Also check that your brake lamp bulbs are a "reputable" make. Some cheap lamps draw the wrong current, and can occassionaly trip the warning control unit.
