I'm guessing snapped, or disconnected, cable?
Just how hard a job is this likely to be?
Yes,if the big nut is finger-turnable,try tightening it up,or try the manual crank thingy in the small hole in the middle.Hoobs wrote:Is that found under the little pop-out panel just back from the switch?
