Quick question, the above are 4x100 fitment, anyone heard of or seen these fitted to an e30? Come in 16 inch, ideal? after something different
renault GTA 4x100 wheels fit?
kingludba
leeparkes
Do you know what offset they are? and iirc Renault have a smaller center bore so would need to be machined out.
abhardwaj1990
Renaults have a larger centre bore of 60.1, so you would require spigot rings.
Offset tends to vary on them from 38-45, so to run on the e30, you would need around 15-20mm spacers for a good fitment.
monkey
wot about scenic 16" steels banded with 16" bmw trims . should look
BEMER_LAND
like thesewot about scenic 16" steels banded with 16" bmw trims . should look
cool
if i rember right the old renault wheels are imperal sizes and a pr*ck to get tires for, might be wrong on this model ones though
