il get things posted up later on when i have more time
http://www.vag.net/viewtopicphp?f=63t=8098
baz
its A LOOKALIKE. its not going to be doing 140mph and going on its roof. its a 318i and now weighs about 3 tonnes so personally i have no concerns for its intended use.Jhonno wrote:That isn't scaffold to make the cage is it...?!
Lookalike or not.. If you have an accident in it, the scaffold will spilt open/fail, you don't have to be sticking on it's roof at 140mph. Mind you, you'd have already likely put a hole in your noggin with those brackets. Fuck that for a laugh..stbaz wrote:its A LOOKALIKE. its not going to be doing 140mph and going on its roof. its a 318i and now weighs about 3 tonnes so personally i have no concerns for its intended use.Jhonno wrote:That isn't scaffold to make the cage is it...?!
I am worried with good reason.. So you are saying cage builders use seamless tube for no reason when they should be raiding building sites....?! Never mind putting pointy hard bits right where a head would go.stbaz wrote:honestly mate....dont worry yourself
i tried to split this pipe with the bender and it broke the forming part clean in half down its lenght with 25 tonnes of pressure on it....i have no concerns. il post a pic of the bender tomo
